Csim96
I recently moved into a new flat that is fitted with a horstmann E7 water heater.
The tank has 2 elements connected, one at the bottom of the tank for overnight E7 heating and a one at the top for the boost function (boost function works fine).
I have searched about online and believe that I am setting the timer correctly by turning the dial so that the time lines up with the “winter time” mark on the unit. Although every morning (5am) when I have checked it the timer dial has stopped around 9pm?
I have tried resetting the correct time and the timer starts clicking again although stops around the same time, any help would be greatly appreciated.
