Horstmann Electronic 7 | on ElectriciansForums
Discuss Horstmann Electronic 7 in the UK Electrical Forum area at ElectriciansForums.net
polo1
Glasgow
Think I’m missing something here. Have been asked to remove a Horstmann E7 BX and replace with an Electronic 7.
The existing set up is two immersion elements (top & bottom) in one cylinder, 24hr top and O/P bottom
Now, the BX has connections for both the incoming off peak and 24hr supplies, likewise outputs, but the Electronic 7 only has one set of terminals for the incoming supply (L/N), and separate outputs for off peak and 24hr supplies. The spec says it’s suitable for two immersion elements.
Surely both O/P and 24hr supplies do not go into the same terminals???!
Any advice?
Ok, now clarified. The Electronic 7 can only be used on a two rate meter, not on a two meter supply (which is what I’m dealing with).
There apparently isn’t a suitable programmer for this setup, to do what my customer wants - limit the time the off peak charge is taken.
Reply to Horstmann Electronic 7 in the UK Electrical Forum area at ElectriciansForums.net
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
