Hot Neutral | Page 2 | on ElectriciansForums
Discuss Hot Neutral in the Australia area at ElectriciansForums.net
M
mayfair
Hi Guys
Have a 3 phase installation 3 phases plus the neutral are fed by 25mm cables into 63A circuit breaker then all split of into the 3 RCD's with 10mm cable inc the N lives are all warm but Neutral is hot checked screws for tightness etc no circuit is reading more than 41 Amps . Any ideas???????????
Cheers
Mayfair
All the computers and all other loads need to be on when you current clamp the neutral conductor to give you a realistic reading.
You may find you will at least need to increase the size of the neutral conductor as a minimum.
think so - oversize the neutral on 3-phase 4-wire if neccessary
the ordinary clamp wont measure harmonic currents although i think overcurrent protection (if used on a neutral) would operate
may not be that anyhow
Reply to Hot Neutral in the Australia area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
