Hot spot thermometer.... Homebase | on ElectriciansForums
Discuss Hot spot thermometer.... Homebase in the Electrical Tools and Products area at ElectriciansForums.net
Whilst it's clearly aimed at the DIY market, i.e. is not a calibrated, professional tool, it does a lot for very little money, and with a 2-year guarantee, you can't go far wrong, so long as you're not expecting precision. Good reviews on Amazon.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
There are cheaper ones available;
I've had one, not the above, for over 20 years mainly for measuring air temperatures but have used it on cable connections in Commercial buildings and found hot spots.
I used something like this eears ago to check for loose connections on a some pretty heavy sub mains on a big site. There had been a fire in one of them, so everything got checked when it was loaded up.
I don't know if it'll just sit in my van and never get used.
I have one of these https://uk.farnell.com/fluke/fluke-ti9/thermal-imager-160-x-120-15cm/dp/1700079
[ElectriciansForums.net] Hot spot thermometer.... Homebase
great piece of kit for checking control panels and DBs. Also really handy for finding joist under plasterboard. Worked a treat on my bay window for putting the curtains up !
i have an ethos one. had it 5 years. cost about £20. works perfectly. main use is electrical ( hot cables/switches etc. and checking the freezers are @ -20.
Has anyone any experience with these?
Keep being tempted, not exactly something that will break the bank but could end up paying for itself in a few hours on a breakdown.
I just brought the flir C3 I'll let you know how i get on with it tommorow
Occasionally you find a warm object (36C) that keeps moving - Reflection of your bare arm , on some shiny surface -at just the right angle .
(Those ghost hunters have a lot to answer for)
Reply to Hot spot thermometer.... Homebase in the Electrical Tools and Products area at ElectriciansForums.net
Bought some just for that purpose ...... but never been asked to show them :(
I concur with all the above. Own the quickwire strippers, knipex ergostrip and stripmasters and would say those three will cover all bases. If...
