Hot Tub circuit plus sockets | Page 2 | on ElectriciansForums
Discuss Hot Tub circuit plus sockets in the Australia area at ElectriciansForums.net
A
AlanWirral
Hi guys,
Think i just need another set of brains on this one as i'm goosed :stuart:
Fitting a supply for a Hot Tub tomorrow. Client bought it off Ebay and i must admit it's a belter. The old owner has kindly given us the 30 mtrs of SWA that it has on now to which i'll be using approx 16/17mtrs. Tub needs a 32amp supply btw
NOW this was all well and good. I'm using a spare way on the 4 way CU in the garage which isn't running much else, 4 sockets and 2 Flo's. Then the client (millionare as it happens) sais 'Oh i want 2 double sockets next to the tub aswell' All i was going to do was run the cable into an isolator on the wall and walla. Now i'm not sure how to get around it. Ideally i don't want to run another swa from that board for the extra sockets as i've already done the groundwork and drilled the hole in the garage etc etc
I COULD spur off the room next to the garden but this means only one socket and it will be a pain as there's decking from the outside wall to another short wall with a raised garden, to which decking has been fitted today for the tub.
Is there a way i can use the hot tub supply for the 2 sockets that i'm not thinking of and of course meet the regs?
Thanks in advance
Reply to Hot Tub circuit plus sockets in the Australia area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Controllers that are intended to control twin immersion cylinders only allow one to be powered at a time.
