hot tub installation advice | on ElectriciansForums
Discuss hot tub installation advice in the DIY Electrical Advice area at ElectriciansForums.net
Carl Alvey
Trainee
nottingham
Hi guys, im having a hot tub delivered in the next few weeks. the hot tub is 32a and will need a 40a rcd from my consumer unit to an outdoor isolator then to my tub.
Ideally id like to install an outdoor socket aswell.my consumer unit is an old steepler one using series e and the largest breaker i can get is 40a.i was thinking of coming from main consumer unit to an outdoor unit which will contain a 40a for the tub and 16a for outdoor socket and ensure that i dont use socket whilst tub is being used??? up untill a time when i can get main consumer unit changed enabling a larger breaker to be fitted.
Would this be ok or would it be better to still install outdoor unit but forget the outdoor socket for now.
Any thoughts and advice would be appreciated.
cheers
Ask your spark to make sure the cable and outdoor unit are suitable to add a socket when your upgrade is done
Do you mean RCD or MCB (or RCBO?) The circuit will need overcurrent and fault protection, usually provided by an MCB, and the hot tub will almost certainly need RCD protection.
Remember you also need to size the cable for a larger OCPD if you plan to increase it in the future. And you also need to pay careful consideration to the earthing arangement of the suply and how to deal with this at the hot tub.
Reply to hot tub installation advice in the DIY Electrical Advice area at ElectriciansForums.net
    • Friendly
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
Personally, I would take a Ze measurement myself rather than rely on someone else's maybe drive by scrap of paper.
2 3
