Hot water and waste in detached garage conversion Discussion Thread | on ElectriciansForums
Guest viewing is limited
Discuss Hot water and waste in detached garage conversion Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Hot water and waste in detached garage conversion
Content of the thread: Hi,
One of my client has a detached garage with access to electricity and cold water. The plan is to convert it to a granny studio.
What's the best way to:
1- get hot water to install a sink/tap and a shower
2- install the waste water drainage
Many thanks in advance for your time.
Kind
Hot water and waste in detached garage conversion to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Hot water and waste in detached garage conversion Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Waste water heat recovery thoughts? Content of the thread: Has anyone worked on / installed one of these? Waste...
M
Heat pump hot water cylinder Has anyone fit one of these? A hot water cylinder with a mini heat pump on top with ducts for air in and out. Heat...
Matt0029
M
