The hottub is 8.1kw so will be 35A max output , I’m going to put it on 6mm 3core swa to an isolator then to the hottub. Would a 40a b type be sufficient for this ? Or would it be better to put it on a 40a c type mcb? Thanks
Discuss Hottub mcb selection in the UK Electrical Forum area at ElectriciansForums.net
I’ve heard of some hot tubs having a spike when starting up and people thatve put them on a type c aswell as b just wanted to confirm what would be betterWhat would be your reasoning for considering use of type c?
Does the manufacturer specify a particular protective device and will ADS be met with type c?I’ve heard of some hot tubs having a spike when starting up and people thatve put them on a type c aswell as b just wanted to confirm what would be better
It is quite an old tub so doesn’t have the manufacturer instructions and cannot find out what it is, the only thing I could find on it is the max output that was 8.1kaDoes the manufacturer specify a particular protective device and will ADS be met with type c?
I'm asking questions as your profile indicates trainee status and OP provides insufficient information to provide an empirical answer.
Reply to Hottub mcb selection in the UK Electrical Forum area at ElectriciansForums.net
