Housebashing wiring helped | on ElectriciansForums
Discuss Housebashing wiring helped in the UK Electrical Forum area at ElectriciansForums.net
Shpark
Chester
Hi all, not a housebasher here, so don’t hate. Wiring my house and need advice. Want to mount the CCU just below the ceiling and bring the cables from the floor above. How do a nicely bring the cable off of the beam so they’re on the wall and then will go into the back of the fuse board? Pics attached
[ElectriciansForums.net] Housebashing wiring helped
I’m going to be the daft one for saying it’s a bit high for a Cooker Control Unit
Consumer Unit. CU… not CCU
Although we can help with some aspects, even a bog standard house rewire can kick up a few problems if you’re not used to the work.
Ask anything, and try not to be put off by some comments.
I do agree with mounting the CU at a more suitable height.
Reply to Housebashing wiring helped in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
