How a big HRC Fuse is made.. | on ElectriciansForums
Discuss How a big HRC Fuse is made.. in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
You aren't likely to see one of these everyday of the week but it is quite an interesting video i just saw, We are childminding tonight and my nephew is on a how its made binge on the youtube app on the tv... Didnt realise they had a firing pin in them mind!
I have a similar one of those in my kitchen, it's not fitted with a striker. 63A 12KV. It's much heavier than it looks.
[ElectriciansForums.net] How a big HRC Fuse is made..
Agree with previous comments, these are for use with HV (High-Voltage).
Why do they contain an explosive-charge?
Put simply, high-voltages can jump through the air (like a police taser for example) and higher-voltages will jump considerably further than lower-voltages; the result is referred to as an 'arc / arcing'.
The problem is that arcing creates very-high temperatures, especially in the area that the arc starts & finishes, which can easily melt metal (basically how welding works). The heat is therefore perfectly capable of damaging electrical conductors during disconnection, and must be avoided.
With this said, explosive-disconnection-fuses are made for use in HV conductors and designed to detonate a small charge during fault-conditions, causing the conductors to separate very-quickly in order to prevent damaging-arcs.
This is a three-phase fuse which is installed on each of the individual phases. It's imperative that all phases simultaneously disconnect, opposed to a singular phase. The "firing-pin" is used to trigger the disconnection of the other phases during a fault to ensure safety.
Likewise.. And I had no idea they would be wound on a spiral like that either. I can guess that compared to a straight element ( which I'd have expected), the spiral adds length so presumably reduces the relative heat-loss conducted out the ends in the event of a small overload.
Yes the firing pin hits the trip trigger for the contacts in the ring main unit so the other phases are also disconnected.
Reply to How a big HRC Fuse is made.. in the UK Electrical Forum area at ElectriciansForums.net
