View the thread, titled "How can I connect a pump controled via 3 independent switches?" which is posted in UK Electrical Forum on Electricians Forums.
B
BMW
Hi
Need some advise. Got a customer who has a air pump switched via a switch fuse. It's a dentist and the pump feeds air to 3 work benches. Now he wants the pump switched by 3 indipendent switches at each bench rather than the one.
I'm thinking a contactor /relay between the mains and pump a switch fuse on the live side then fusing down and wiring the 3 switches like a domestic instalation (2-2 way and an intermidate switch) this feeds the coil to the contactor / relay. That way each switch will turn the pump on and off. The switches can be normal as they are only switching the coil not the load.
Can anyone who has the relative experience see anything wrong in my suggestion. I am a Qualified sparky but this is out of my normal area of work and being on my own have no one to bounce ideas off. Can anyone help.
Cheers
Come on, the needling between electrical technicians and instrument artificers has gone on for the last forty+ years I’ve been kicking around in the industry.
Electrical technicians were always the higher paid, we could do both jobs!
Reply to the thread, titled "How can I connect a pump controled via 3 independent switches?" which is posted in UK Electrical Forum on Electricians Forums.
