How do I get my meter with 2 related meters changed to a single meter with 1 MPAN? | on ElectriciansForums
Discuss How do I get my meter with 2 related meters changed to a single meter with 1 MPAN? in the UK Electrical Forum area at ElectriciansForums.net
Tim25
London
I have 2 related MPAN's which I'm being charged for but I only have the 1 meter, how do I go about getting this changed to a single meter with a single MPAN.
I've been told an electrician needs to check that the one supply is enough to supply my property?
Thanks!
Sounds like a previous owner had some renewable energy systems under the RHI scheme. Maybe change your tariff? Usually these schemes provide quarterly cash incentives for seven years. Do you have a heat pump or biomass boiler or something? It may be that the scheme is still running or could be renewed, are you sure you want to get rid of it?
Reply to How do I get my meter with 2 related meters changed to a single meter with 1 MPAN? in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
