How do I install a Home Media System | Page 2 | on ElectriciansForums
Discuss How do I install a Home Media System in the Home Media Centre Forum area at ElectriciansForums.net
The only problem with those though scratch is the systemline and the NuVo only distribute composite video and not HD.
not alot of multiroom systems can do hi def as yet.
I work for a company at the moment who do home cinema rooms and multiroom and if you want a ps3 and sky HD in 5 rooms you would possibly need:
1 x HD Matrix (probably a 4 x in 8 x out is the nearest to your spec) upto £2000 - £3000 dependant on needs (intellix are quite good)
5 x HD extenders (most use 2x cat6) or hd cables long enough to suit (ethereal are the best ive used but pricey £600 - £800 per set but you can get cheaper ones)
1 x sky box
1 x ps3
either 1 x amp per room or a multiroom system to control it all (the NuVo or systemline could be used but not for the hd video distribution side) (prices depend on the system but again can be pricey)
Oh yeah and it may need programming too system dependant.
Steve.
I've looked around a house that has just been first fix for home automation, as I looked round there was standard cat5 wound in single galv boxes, also a green multicore cable (decided into 4 witting the inner sheeth, looks like a cat5 just decided up) not sure what this is called
I know the lighting in each room will be controlled via a computer/screen..
Anyone know what control panel this all might be connected upto... I'm unsure of what is exactly going on.... Lots of data cable in each room
Reply to How do I install a Home Media System in the Home Media Centre Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
  • Poll
Dahua is good for cameras. The pro Sony cameras are too, not cutting edge but very durable. Texecom is missing from your list of Alarms, they are...
P
water pressure problem, unvented system I'm trying to sort out a problem with low water pressure at my elderly parent's house where they have an...
plomero
P
