How do I wire an emergengy stop button to an extension cord? | on ElectriciansForums
Discuss How do I wire an emergengy stop button to an extension cord? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Chrisx3
london
Hi everyone,
I am trying to wire an emergency stop button onto a 1 gang extension wire.
I have submitted some pictures of the button and the stripped extension wire.
Could someone please give me some guidance on wiring this before I burn my house down? ? ?
[ElectriciansForums.net] How do I wire an emergengy stop button to an extension cord?
  • [ElectriciansForums.net] How do I wire an emergengy stop button to an extension cord?
What is it for? I'm trying to think why you want such instead of some basic switching arrangement....and why in such a cable if you can unplug it?
As above, and what is the rating of the switch contacts? Not all are suitable for controlling the load directly. Be aware that this is not a normal configuration and if it is being used for safety purposes, might not be satisfactory.
Yes, such an emergency stop switch in the wrong situation could well create an emergency.
Hi, Thanks for your quick replies. I am using it to be able to easily cut the contact to a heater which already almost burnt my carpet last week and I was fumbling to unplug it while I could smell it getting worse. I guess I could just unplug it but I wanted something to quickly cut the contact, if needed, as the plug is behind a cupboard and it's not easy to get to a mains switch. Also, your point about the regular switch setup was the original idea but I was gonna paint it red to make it obvious and so decided to go for this instead.
I bought it from here: 1pcs Emergency Stop Button / Stop Switch Twist To Release 1 NO+NC Contact | eBay - https://www.ebay.co.uk/itm/1pcs-Emergency-Stop-Button-Stop-Switch-Twist-To-Release-1-NO-NC-Contact/143219927213?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
They don't give any information with it. I am attaching pictures of the side of the switch with more info.
Thanks again for all your help and hope I can get this to work safely, as it is meant to be a safety feature.
Ok, thanks for the advice, Off to Ebay returns it goes. Thanks for your help. Can you recommend me any other setup for this situation?
From your point of view, a small extension lead incorporating a switched socket with indicator is the cheapest way, safety wise...depending on the heater size.
20A double pole switch will do, only use it when you have to though use the switches on the heater where possible.
it sounds like the heater may not be installed as per the instructions, perhaps a different type of heater or a different location might be a better safety improvement as any kind of emergency stop type arrangement requires someone to be there and press it.
Get a heater that isn't likely to set fire to the carpet or sit you existing heater on a non combustible surface because you can't watch the heater all the time with your hand over the stop switch. Remove the risk.
Aye, reading again, fully, it seems a real problem to be messing with.
Could get a direct line to the fire station, maybe. ;)
If the heater is the problem you should be either getting it repaired or replaced.
Reactions: DPG
Status
Reply to How do I wire an emergengy stop button to an extension cord? in the UK Electrical Forum area at ElectriciansForums.net
That is a big assumption (like a garage saying briefly as you pay the bill, other than the brakes not working, it’s good to go) generaly speaking...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
