UK How do I wire an emergengy stop button to an extension cord?
Status
Not open for further replies.
Hi everyone,
I am trying to wire an emergency stop button onto a 1 gang extension wire.
I have submitted some pictures of the button and the stripped extension wire.
Could someone please give me some guidance on wiring this before I burn my house down? ? ?
I’ve got exactly the same Emergency Stop that I’m adding to my Myford ML7 lathe.
Though I’ve had it 45 years, it was left to me from my grandad, though I realised it was using 7 core cable, as per vehicle trailer wiring. Due to the kick of the motor when starting in reverse or forward, the cable wore through and shorted out, nearly 💩 myself as it was right in front of me.
I’m putting new 3 core from a 13A plug to the existing Dewhurst Forward | Stop | Reverse switch, which I’ve just cleaned and rebuilt, but with the Emergency Stop between.
However, I hadn’t realised the ES was 3A, so if anyone can suggest what would be best, I’d appreciate the information 🙏.
I’m not an electrician so have asked locally, but had no response
The estop should be used with a relay contractor.
You would be better looking for a direct online start stop control box and this may come with estop or you will be able to add it in circuit to work with the internal control circuit
I apreciate your response, but as I say, I’m not an electrician so what you’re telling me is way beyond me.
I’m trying to get a qualified electrician but I’ve had bo reply
This claims to be suitable for a load of up to 15A with no additional components.
That should be ok I would have thought.
I would prefer a direct online starter with overload protections but it doesn't have to have one just gives extra protection for overload
Please check the original post, its 4 yrs old and with all respect anyone asking how to connect a critical safety device is delving in a legal quagmire and the forum will not advise without further info but on a basic like this thread closed
Status
