How do you R1+R2 test a lighting circuit spured from a ring main | on ElectriciansForums
Discuss How do you R1+R2 test a lighting circuit spured from a ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
petertwine
Hi Just wondered if anyone can give me abit of advice when inspecting and testing how do you go about a lighting circuit R1+ R2 and Zs.. ect when it is spured from a Ring Main circuit. Any info would be gratefully received
thanks
pete
I'm positive on this but the Light is a LOAD and sholud not be tested as it isn't part of the installation.
You wouldn't test Zs on a hoover you plugged in would you?
Ok I'm now looking WAY to deep into this. However.
If the light or lights are wired in T/E with switches ect from the FCU then they would become part of the fixed installation.
The Ring Final Circuit would become a Distribution circuit for the FCU.
The light wired from the FCU would be a Final circuit.
So yes all tests would be required from the FCU in order to ensure that the BS1362 fuse blows within 0•4 seconds.
It's the same principle as feeding a sub-board in your garage from a consumer unit in your house.
Reply to How do you R1+R2 test a lighting circuit spured from a ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
