OP
lauriehurman
Pleease Sir, sir sir. I know ... me, me, me!
Discuss How do you test Earth Bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A lot easier to remove the earthing conductor.You would remove the bonding to test ZE though.
to achieve touch voltage of less than 50V
Although why would you disconnect the bonding to remove parallel paths? Parallel paths would be present under fault conditions.
Reply to How do you test Earth Bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
