how do you wire in a spotlight? | on ElectriciansForums
Discuss how do you wire in a spotlight? in the UK Electrical Forum area at ElectriciansForums.net
I want to start installing spotlights but I find the connectivity difficult as they don't come with ceiling roses. The only way I could think of is taking the switch wire to a junction box and then wiring the corresponding spotlights off it, can it be done this way? or what is the correct procedure?
Are you a sparky or is this a DIY job?
If the manufacturers give you a recommendation on how they should be wired then I'd suggest that this would be the best option. What make and model number are the spotlight fittings?
Most sparks can look at something they're unfamiliar with and figure out a compliant way to install it. If you're struggling with the concept of spotlights then I think you should post up your location so one of us can come to do the job for you.
NO thanks, rather do the job myself. If your going to be any help how about answering the question, im not looking to provide work
im a sparky, just want general understanding. the manufacturers will probably highlight how to install one not a dozen !
It is unusual for a sparky to not know the answer to this one, but not beyond the realm of possibility.
Perhaps you could let us know a little more about your electrical experience and qualifications.
As a sparky you will understand why we don't want to hand out advise when we could potentially drop ourselves in it if the advise was to be musunderstood.
Yes im looking for advice in relation to my question, not for someone to come do the job for me.
That is fair enough, but based on your first post I am afraid the best advice that can be offered is to hire a suitably experienced electrician.
If you can enlighten us as to your knowledge and experience of electrical installation work then we can give you further advice best suited to you.
Reply to how do you wire in a spotlight? in the UK Electrical Forum area at ElectriciansForums.net
I did take this picture before of the wiring in the spotlight if that helps. The earth is bottom right I cut this to get the sleeve off to put...
