How do you | Page 2 | on ElectriciansForums
Discuss How do you in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
How do you keep the door open that shuts behind you and get locked out and you keep pushing the door entry system to say to the customer I'm out side, open the door.
Today in and out of the flat ground floor
Taking the gear in like a camel. sod this out came the cold chisel and rammed it under the metal door. Now I can get in and out.
Had this very problem in a block of flats in Southampton the other day, door entry system broke so tenant is waiting to give me an electronic pass and a key to her flat then goes off to work......I then proceed to her flat.....then immediately back to my van leaving both keys in the flat ? ?
Reply to How do you in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
