P
propelera
I study Power Engineering in University. Today I asked my lecturer to explain me exactly how atom's electrons act under spinning rotor's magnetic field, that generated dynamic electricity. But he even didn't gave me to finish my question and said : "Explaining it to you is useless, you are not capable of understanding it". I felt very angry hearing these words, like I was an idiot. So I have some thoughts about electrons behavior under spinning rotor's magnetic field and I want your answer, is this theory correct and if it's not than why?
here is my theory:
Consider this is simple atom:
When magnetic field cross atoms, if magnet's north side (+) is near to this atom the center of electron's path (gray circle) will not be on the center of nuclear, it will move toward magnet, because magnet has north side (+) and electron has (-) potential. As I believe the Voltage (U) is distance between center of nuclear and the center of electron's path. And the number of these atoms make amps.
That's why increasing rotor's magnetic field makes more voltage, and that's why air's ionization happens around high voltage wires (voltage like: 220 kv, 500 kv). Nuclear has not enough power hold electron and so this electron moves to new air's nuclear. I think that also explains why Current and Voltage are 90 degrees out of phase.
Please read my theory and tell me I am right or not, I really want to understand how this everything is done.
Also my lecturer told me that every information I can find on internet is written by fools and foolers are reading them. So I want to tell him that he is WRONG!!!
Basic stuff mate that's why the fans in our bogs sometimes pack in...............thought everyone knew that !
Thank all of you guys for response. So am I right or wrong? If I am wrong than I really don't understand (I have learn't that, but could not UNDERSTAND) how rotating magnetic field makes electricity, and what connections do Voltage, Amps and Currency has. Again I have learnt the formulas, but only formulas didn't gave me the DEEP UNDERSTANDING. Can you link me to the articles where I can find more information about how voltage, amps and currency is connected deeply in atomic level?
Electricity and magnetism are the two sides of the same coin.
They mutually affect each other.
Yes, a magnetic field will cause electrons to move (current...) and an electric current produces electric and magnetic fields.
Understanding why, I'm sticking with my Physics PhD theory!!!
Yes, exactly a magnetic field will cause electrons to move (current...) and an electric current produces electric and magnetic fields.. I know that is happening but can't explain Why it is happening.
magic electrickery. at the end of the day, this earth is only an electron orbiting the nucleus (sun). it's all relative as the bishop said to his neice.
The truth is prop, is that nobody really knows why, there are many things that you have to accept as 'Because it does!!!'
The deeper you dig down, the conceptual difficulty rises exponentially! Hope you're good at Maths if you want to carry on.
How electrons act under rotating magnetic field?
propelera,
Darkwood,
