Discuss How many 4mm T & E down a 25mm conduit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
why????really you should only be using singles in conduit.
should think so. 2 x 2.5mm will go in 20mm conduit, just.Can you get 2 4mm T & E cables down a 25mm conduit that only has a kick and a female bush one end and a 2 g socket including a bush the other end ?
I've been in that situation many a time. The solution is:Can you get 2 4mm T & E cables down a 25mm conduit that only has a kick and a female bush one end and a 2 g socket including a bush the other end ?
I'm hoping he may have finished the school job by nowI've been in that situation many a time. The solution is:
Leave approximately 200mm of the sheathing on 1 cable or enough to make entry to the point of termination with sheath around it.
Strip the sheath from the 200mm mark to approximately 200mm short of where the other end terminates.
Now you have 3 building wires with no plastic sheath making them bulkier. Legal if run in conduit.
Its sometimes easier to strip as you go.
Keep the whole sheathing on the second cable, the conduit is wide enough to accommodate the cables as per described. Most important that any cables exposed should be sheathed.
Reply to How many 4mm T & E down a 25mm conduit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
