Hi all, apologies if my description & terminology is 'novice'!
I need to relocate the light switch box (with x2 switches) which currently is in a Cupboard in the downstairs entrance hall; initially this box was in the Hall but part of the Hall was subsequently blocked into a Cupboard, trapping the Hall & Landing switches there. This currently is inconvenient as it requires one to first open the Cupboard Door before switching the lights.
What I intend to do (but will heed advice to confirm it is safe & complying to wiring regs) is described below:
Thank you - Chris
PS. If it helps I can upload a couple of photos.
- Channel into the plaster, horizontally from the existing switches box to just outside the cupboard door, where I intend to install a new light switch box (x2 switches - as now). The distance is about 12 inches.
- Retain the existing light switch box (plastic), but use it as a junction box, and replace the switch faceplate with a blanking plate.
- I intend to extend the cables coming into the original switch box (which will become the junction box) by soldering all cables, and using shrink sleeves.
- Use some form of ducting leading to the new light switch box.
- Feed the extended cables (from the original light switch box) through this ducting and terminate in a a replica switch in the new position.
- I realise the 'normal' & conventional way of doing this would be to go vertically up but due to coving etc, as well as the proximity of the new position of the light switch I'd prefer to go horizontally across to the new switch position just outside the Cupboard door); as noted above this is a short distance of about 12 inches.
Thank you - Chris
