How this wires has been pulled? | on ElectriciansForums
Discuss How this wires has been pulled? in the UK Electrical Forum area at ElectriciansForums.net
M
Mixmaker
Hello everyone! Does anybody know how this 3 cables from loft has been pulled down to first and ground floor,if the coming through 3 holes in the wall.?Is there any specific method of pulling wires?Please help. Thank you very much.
[ElectriciansForums.net] How this wires has been pulled?
stitch drilled out a brick up top and a brick down low then dropped down cavity. use a mortar gun when reinstalling the bricks. not a great installation method as you can't support the cable throughout its length
The Sparky must have been blind pulling his wires like that
It's going to be pretty difficult to be certain without actually being there. Can you see anything else under that insulation? Do they disappear into a flat tube behind the plasterboard in the room below? Can you try a cable tracer? Can you access the flat below and see what accessories are in line with them further down? Daz
Lets just say maybe you are correct, never mind that old tosh about cable support, just be grateful you have got down a cavity and not destroyed the clients house in the process. Geez
Reply to How this wires has been pulled? in the UK Electrical Forum area at ElectriciansForums.net
Which begs the question, where does the second brown wire come from?
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
