How to add exterior lights to garage opener? | Page 2 | on ElectriciansForums
Discuss How to add exterior lights to garage opener? in the USA Electrical Forum area at ElectriciansForums.net
Ohio
[ElectriciansForums.net] How to add exterior lights to garage opener?
i just installed a new garage door opener. Does anyone know of a way to get my exterior garage lights to operate when the garage opener lights are?
currently the exterior lights are just controlled by a switch in the garage. Thanks for any information.
Assuming the garage door opener and the outside lights are on the same circuit, if not then your suggestion will link two different circuits and create a potentially dangerous situation.
Dave it is coming from the same circuit as the door opener. Read the reply again I said nothing about 2 circuits.
Reply to How to add exterior lights to garage opener? in the USA Electrical Forum area at ElectriciansForums.net
J
Exterior grouting with the wet weather. Hi, I've laid an external porcelain patio on a sand and cement bed with ultrascape priming slurry. It...
Jed2009
J
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
