deano the spark
hi all,
looking for some advice please on how to carry out an r1+r2 reading on a 35.mm,(3p+n)4 core,swa cable. it is a sub main cable with a parallel 35.mm cpc. however both ends are terminated into a steel main panel,and a steel distribution board respectively, with a number of other parallel earth paths. the installation is also galv conduit and steel trunking continuous and all linked back to main panel/distribution boards.
i believe that i would have to disconnect both glands of the 35.mm swa and parallel 35.mm cpc from both ends,and link across each phase (individually) to parallel 35.mm cpc to get my true r1+r2 reading.
(not practicable i know) but was just double checking .
hope you can help
many thanks
deano
hope you can help
many thanks
deano
