How to change hours immersion heater | on ElectriciansForums
Discuss How to change hours immersion heater in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Jacko14
Walkden
How do i go about changing the hours in which my immersion heater charges? Its on 2:15-7:15 at the moment but we dont need 5 hours charge , any help would be great
  • [ElectriciansForums.net] How to change hours immersion heater
What makes you think you don't need the programmed 5 hours to charge a cylinder that size on off peak electricity? It won't draw power once all the water has been heated, since the thermostat in the bottom immersion heater will switch off.
The programmable 'boost' function operates the upper immersion heater on full price electricity, and is used to make the water hotter in the evening if it has cooled off a bit too much, or if you have used up the complete cylinder full during the day.
This is the second thread on the same subject.
Status
Reply to How to change hours immersion heater in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
