The only other thing done in the house concerning the electrics was they had a smart meter fitted. Could this have any relevance
So the Cowboys who installed the boiler didn't leave any paperwork, a MNWC as an example?The problem is it's only my logic that says it's them. There is no proof.
I've changed the fuse to a plug in mcb for them, for my own peace of mind I don't want them struggling in the night They can just flick the switch instead.
Doesn't solve the problem just helps them get power back on.
OP I think by now you should have got an electrician in to check the installation. It's possible an appliance is causing the fault, but you need to be sure. Adding a plug-in MCB, might make it easier to reset the faulty circuit, but you can't just keep resetting it every time. It's possible at some point the MCB might not operate correctly, which could be dangerous.
Call in an electrician. In the meantime, disconnect every unnecessary appliance.
Thanks for the reply.
Your right pal I'm not a spark but I'm not a numpty either if you know what I mean. Yes I do have a multi meter. In your opinion is it something I can do with the help of good people like yourself ?
For reference this is not for a job but just to help my pensioner in laws out as it appears someone has, like I said, put a 15a fuse into a 30a carrier. I just want to sort it for them so they don't lose all sockets as they currently have done 4 times in the last 3 weeks.
Thanks for any constructive advice I really do appreciate it.
You are right as in no they wouldn't have to produce a minor works for a plug in boiler. A professional firm would have provided a switched FCU hopefully on a dedicated circuit with a minor works or EIC.Presuming that's a minor works notice. Would that be necessary as the boiler just plugs in to a nearby socket![]()
Best thing to do would be the below.
Is this possible with a multimeter and a loopcheck socket tester![]()
Dedicated circuit for the boiler? Is that more professional? Why is that?
