how to choose component? | on ElectriciansForums
Discuss how to choose component? in the UK Electrical Forum area at ElectriciansForums.net
dubai
hi guys hope that your doing good i need help
i want to know how to choose MCB RCCB...... contactor overload cable size etc,,,,, for any load
thnak you hicham
The question is a broad one and the answer would fill a book, so not easy to answer on the forum. Also, although the principles are standard, the preferred methods will differ in detail under different regulations in different countries.
If you have a specific requirement, by all means post some detail.
Reply to how to choose component? in the UK Electrical Forum area at ElectriciansForums.net
Okay, thank you. The language just threw me because it was, you MUST remove power, then it says to test, as in the middle pic, with power...
If you are using Zdb you do not add on Ze as that is already incorporated into Zdb.
