View the thread, titled "How to connect motor?" which is posted in Electrician Talk | All Countries on Electricians Forums.
It looks like a normal 3 phase isolator with the feed going in top and the outgoing from bottom. The only difference is that it has loads of terminals on bottom. It feeds one motor but have 6 outgoing cables
Pictures would be very helpful if you could attach a few of the isolator and motor terminal box and even the supply where it comes from the control panel along with the contactor/overload arrangement.
It could be a manual Y/D starter (manual change over) switch.
Have you opened up "the box"?
If it is what i think it is, then it probably does not comply with legislation now, & no I don't mean BS7671.
Without more info then there is no more I can suggest, sorry.
The casing is clear so you can see the switch and terminals. It is just an on or off switch. I have no photos at moment
What are they in contravention of , we look after several grain stores that still have these on the main fans ?
The problem is we don,t no what this isolator/starter is, no photo,no manufacturer type/series and were on page 4 . If we can,t definitive info we might as well get a mini bus and go down and have a look
Now that sounds a bloody good idea. Who’s driving the bus? The Electro-bus-ters team arrive en mass. To drunk to see what we're doing but we’ll muddle through somehow.
**** that I want an failsafe UPS beer supply to the Bus, operation of the bus switches only to be undertaken by by sober authorised persons, (that’s ****** that idea up), When we reach county borders the supply system swaps to the local (frequency) brew.
I can see this ending in a muddy ditch at the side of a field!
Reply to the thread, titled "How to connect motor?" which is posted in Electrician Talk | All Countries on Electricians Forums.
