How to deal with Pyro Cable? | on ElectriciansForums
Guest viewing is limited
Discuss How to deal with Pyro Cable? in the UK Electrical Forum area at ElectriciansForums.net
Mattja
UK
Situation is there's some 53 year old pyro cable that I need to either remove, or make dead, or cut short and push back into the wall having ensured that the still-live end cannot short out the circuit or come into contact with anything.
No hope of fully removing it, as it goes up the cavity and I don't even know the route it takes.
Chances of finding the junction box that connects it to the downstairs power ring are remote, I suspect it connects at a junction box fixed into the wall behind fixed cupboards, next to pipes, in a kitchen, and below the bath (bathroom above the kitchen), however I cannot be sure. I also am not sure I can take the cupboards down without damaging them (I'm no carpenter/kitchen fitter).
SKIP TO THE POINT:
The obvious thing to do seems to be to cut the cable just after it leaves the outside house, fix the end in such a way that it's not going to short the circuit or make live anything it comes into contact with, and shove it back into the wall (then cement over it). I've not had to deal with pyro before, how would you recommend going about this?
NOT in the way you are proposing.
You have to find the other end and disconnect it or disconnect the whole circuit.
Or correctly terminate the end you want rid of in a suitable box, NOT shoved back in the wall
You need a Kitchen fitter or Carpenter.
No,the "obvious" thing to do is not do what you propose
SKIP TO THE POINT:
Am I reading this correctly - you mean literally just cut it short and cement over it? Tell me I've misunderstood - surely you would disconnect it from wherever it is fed from???? If not then I would suggest you need more training before working in anyone's property. And it wouldn't matter whether it was unwanted pyro, T&E or whatever - the principle is the same regarding this issue. Daz
Had another idea, it wouldn't be an unreasonable place to put an outdoor socket (where the pyro comes out of the wall)
Not sure what you mean "tool up with a phone" is that a sarcy reply to the previous well meant reply, or something else?
My lame sense of humor, meaning the tool for the job is a phone to call in someone to deal with the cupboards.
Ok what I meant in full, thought this much was apparent sorry: pull out the fuse for the circuit it's connected to, cut through the pyro close to the wall, (and here's the bit I needed to know about dealing with pyro for) put a new cap/gland or whatever pyro uses on the end of it and put a suitable box or something over the end of it so it's not going to short circuit or connect to anything etc, expand the hole in the wall so it can be pushed in there, push it far enough back that the end can be cemented over (it goes into the cavity), and then cement over it.
Not for a second (again I thought this was clear sorry) did I intend to just snip and shove. That's why I was looking for advice on how to do that with pyro.
But having taken advise from the first reply here I should have help on the way in a few days so I can get access to the junction box at the supply end and disconnect it there.
Reply to How to deal with Pyro Cable? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
