How to Find the location of a fault - Puzzler | Page 2 | on ElectriciansForums
Discuss How to Find the location of a fault - Puzzler in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thats interesting.
I was going to ask whether anybody actually uses this in fault finding.
CH
Yep, I've used it just the once doing initial verification on a nut house wing. Was doing my tests at the board, got 0 on insulation resistance, put it to continuity and got an extremely low reading. Guessed that it was a dead short as a continuity will only pick up a reading when conductors are touching, took the reading, looked up the table for R1+R2 for 2.5 t+e, and divided my reading by it. About 4 metres it worked out as, so measured about 4 metres from the MCB and lo and behold there amongst about 20 other cables in basket was a cable that had been severely twisted to the point that internally it was short to earth. It seemed like a common sense approach at the time, but I still was chuffed when the method worked perfectly!! Now if only the same worked for insulation resistance reading, life would be so much simpler!!
This reminds me of many years ago whilst looking for a fault on a Co-axial underground cable.
We used an ocilloscope thing that put out a very narrow pulse and measured the time it took to reflect from the fault. So having got 35 metres or so we set out with the digger to have a look.
We found no fault at all within about 15 metres both sides of the distance. So we checked again with the kit and got the same result. ( 35 metres ). Then we lifted the examination cover and found 20 metres of cable coiled up in the hole..:eek::eek::eek:
Reply to How to Find the location of a fault - Puzzler in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
