Quite often I see conduit going into an adaptable box or conduit box 'outside'. This is fine if it is coming in from the bottom, you can just use a normal adaptor to go into the box, but often it comes in from the side and the adaptors are not IP rated.
I just wondered if anyone here uses conduit as in the above example (or even when conduit has to enter from the top of the box) and if so are you completety happy that it will be waterproof?
I tried one of the MK Masterseal cable Glands (for conduit) which supposidly gives you a weathertight seal, but it didn't fill me with confidence (falls out easily) so I didn't use it.
Cheers all..
Cheers all..
