How to install an earth rod, or not as the case maybe | on ElectriciansForums
Discuss How to install an earth rod, or not as the case maybe in the UK Electrical Forum area at ElectriciansForums.net
So, so long as you use "quality" copper wire this method is just fine ;) hey though I did like that expensive bit of testing kit he had, and how simple to use as well. :D
Haha! Good lord that is some high quality workmanship, who needs bolts and clamps when you can justake wrap some conductor around and then give it a wee tug with a pair of pliers!!
The best bit about the video was the fact the head of the hammer comes flying off mid strike, that was the icing on top.. it's okay though, they are doing this on the cheap ;)
Reply to How to install an earth rod, or not as the case maybe in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
