How to mark conduit bender? | Page 2 | on ElectriciansForums
Discuss How to mark conduit bender? in the UK Electrical Forum area at ElectriciansForums.net
Lincoln
Good evening Gents
Om after some help and advice please on setting up a new conduit bender.
Im wanting to ask how to score a mark on the forming wheel to indicate bending points etc?
I usually do the way of doing a bend then offering up and trimming excess off but would like to learn the old school way of measuring exactly please and seen many formers with marks on for bending points and wondered how the find it out please!?
Never understood why formers don't come with a right angle on the rear radius to make lining up back of bend more accurate.
I mean you could go with a square but I just eye it for the sake of a few mm.
Nothing like ignoring the experts is there? they have obviously got the correct idea, if you chose to ignore it do it at your peril.
:eek:
There is as far between artisan and adequate as there is adequate and dog rough, the price reflects.
Can't imagine theres much call for artisan conduit installs but theres a lot for quick adequate ones.
:eek:
Didn't want to give you a disagree icon, but I do disagree with your thinking
VORTIGERN you can also use a 3 piece coupling or a union I don’t know what you call them to eliminate screwing it in
sounds interesting, not that I have ever used them I just assemble down and offer up to the hospital saddles I usually use. Like to see a pic of what you mean if poss.
[automerge]1577832045[/automerge]
Longthread and coupler (aka runner)
The question was rhetorical just getting the OP to think about the practicalities outside of bends.
We don't have them in the UK, we use a running coupler instead.
[automerge]1577836058[/automerge]
This shows how a 3 piece coupling works, it's not to different to a running coupler, just bulkier.
Assembling the conduit then fitting it in to the saddles only works up to a certain length of run, and when there aren't too many obstacles in the run. Otherwise runners are not so easy to avoid.
That 3 piece coupling doesn't look very good. Does the ferrule ever catch the free floating part and unscrew when tightening together? I suppose you would need one of those things as a running coupler wouldn't work with american taper threads!
I have never heard of a running coupler. Learn something new everyday. But then I have never had the need for them. I think they look a bit untidy though and would spoil the line of the conduit install. Although I can see they would have their uses.
They do look slightly untidy, but they are necessary whenever you can't spin the conduit due or bends/obstructions or the conduit is just too long to assemble on the floor and lift into place.
How do you get over the problem of not being able to screw the conduit together? I guess you could fit a fit a small adaptable box, but that would look worse in my opinion.
Reply to How to mark conduit bender? in the UK Electrical Forum area at ElectriciansForums.net
