How to open this holder? | on ElectriciansForums
Discuss How to open this holder? in the Lighting Forum area at ElectriciansForums.net
uk
I just cannot seem to "twist" this to open it and replace it with a new one. There does not seem to be any locks or screws holding it. The cord hold is unscrewed, so it is not that holding it.
[ElectriciansForums.net] How to open this holder?
Sparks tool kit, screwdriver and hammer, you've exhausted half the tool options.
In other words tw4t it, after safe isomolation.
If you look at the outer edge of the metal ring that the build lugs fit in to Ullapool see a bit of the metal the ring is made of where a bit of it sticks out and it grabs against steps in the plastic bit ull need to bend it inwards to stop it gripping against the outer bit
sorry but in my photo in the first post, I cannot see the "bit" that sticks out.
Shouldn't message when drinking
Wizzard if you look in the inner of the metal ring ull see the bit that's bent outwards and if get a small driver down outer of metal circular bit and bend it inwards it will then unscrew done loads mate promise
Reply to How to open this holder? in the Lighting Forum area at ElectriciansForums.net
Silent Running Toilet eluding capture I have three toilets in the house. Two have been "silent running" for a while now (constant trickle of water...
slocombe9
Only thing is, its not 2 way
