How to open this holder? | Page 2 | on ElectriciansForums
Discuss How to open this holder? in the Lighting Forum area at ElectriciansForums.net
My that's a big one
That lampholder is not suitable for use in the light fitting the OP is asking about, fitting that as a replacement will leave exposed live terminals in the fitting. It needs to be replaced with the same type of lampholder as is already in there.
Many thanks will try it out. Is this a common - to "fuse" it at the production time?
It's not fused tigether, the lampholder is screwed together and a little metal tab locks it a bit like a ratchet mechanism. It is possible to get them apart again if you can get to the metal tab and push it back, but it's really not worth the effort if you're replacing the lampholder anyway.
Will try and open it as Gary suggested. If not, brute force. I will need to take the lamp off the wall - I have 8 of these! I am going to replace these with E27 - better daylight colour choice. Bayonet LED does not fit in the lamp as the neck of the holder restricts it.
Thanks guys. I will replace all the holders in my first post with this E27 type holder. I am assuming that it will be ok to use a LED bulb up to 9 to 12W?
[ElectriciansForums.net] How to open this holder?
Could not get it to open, so cut the cable near the cord grip, unscrewed the cord grip and the socket came off. Cannot see the lock mechenism in it, so this option.
Wizzard you managed to get it apart ?
Thanks a lot Gary! You were right. I managed to break one but an electrician friend was around and managed to get to the the "lock" shown in the photos above. Rest of the 10 or so replacements were easy!
Thanks again. I never ever thought that old bayonet type had this "stupid" lock mechanism in it.
Reply to How to open this holder? in the Lighting Forum area at ElectriciansForums.net
Silent Running Toilet eluding capture I have three toilets in the house. Two have been "silent running" for a while now (constant trickle of water...
slocombe9
Yeh… about 3 quid for a new switch… But I think there’s too many wires there for you to attempt to change it yourself
