How to remove Bosch fridge display panel
I need to change the door on a Bosch fridge freezer KGN49AI30G
Looks like a straightforward job apart from the requirement to remove the display panel built into the front of the door.
I can't see any gaps that would let me prize it out. Can anyone give me any tips on how to remove this without marking the door or the display?
look up under control panel...two slots on mine to put flat head small screwdriver in slot and shove towards you at an angle and door will pop...repeat on other side. Its a clip inside. I am tying to get to control panel LED ring...can't figure that one off now I have panel off
