How to remove integrated Neff fridge freezer | on ElectriciansForums
Discuss How to remove integrated Neff fridge freezer in the The Welcome Forum area at ElectriciansForums.net
Marnhull, Dorset
I have a 7 year old integrated Neff K42 fridge freezer and I need to replace a couple of the attached kitchen cabinet doors hinges. In order to do so I need to remove the appliance from the casing but cannot figure out how to do it.
I have removed all of the visible screws on the fridge/freezer surround including one securing the freezer to the bottom of the carcase and assumed I would then be able to pull it out but it's stuck firm at the bottom.
Any ideas?
Normally just a bracket screwed into the carcass top and bottom.
Likely rubber feet on it, so might just be sticking as you try to slide it out.
It’s a bit of a faff getting it all back together… to get the cupboard doors to open with fridge doors.
Welcome to the forum :) Did you manage to sort out your issue?
Reply to How to remove integrated Neff fridge freezer in the The Welcome Forum area at ElectriciansForums.net
I have a Hoover HBCP3150, integrated fridge freezer. Probably 3 years old. It's immaculately clean inside and out. It looks brand new but the...
If properly designed as "frost free" then it won't. As i described above, such freezers typically have a finned heat exchanger (HE) with a fan...
