How to rewire a table saw | Page 2 | on ElectriciansForums
Discuss How to rewire a table saw in the The Welcome Forum area at ElectriciansForums.net
Ok will do cheers ,that's the motor stripped, found the other wire, both are red so which one is live or does it matter?
think you need professional help here. an expert can determine what goes where, test it, and make sure it's safe. depending where you are, 1 of us may be close to assist.
Live in Airdrie Scotland if anyone close by
If there is no body close who can help, do you know of any Motor Rewind firms nearby, that could be your best bet, shouldn't be expensive.
If altering the saw to 45 degrees causes the cable to pull out, it suggests the cable is too short.
Anyway, if you connect up the two wire and the saw goes backwards, you just dismantle again and swap them round.
Do we know what type of motor this is?
If not,he may get alternate results :)
Reply to How to rewire a table saw in the The Welcome Forum area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
