How to slow down fish pond pump | on ElectriciansForums
Discuss How to slow down fish pond pump in the Australia area at ElectriciansForums.net
P
portisheaddan
Hello everyone in here. I am new to the forum so saying hi!
I am after some advice regarding an electrical garden fish pond pump.
I have bought a pump that is quite honestly to big for my pond. Its pumping too way to fast - twice the speed i need. Although I have a knob on the side that I can turn to restrict the output, this wont slow the pump down and will still consume too much electricity.
My question is - Although the pump is sealed - Is there a component/components I could get at say maplins etc that I could solder or put in line to reduce the power or voltage to the pump ?????
Make any sense?
Is there any way or doing this? It has to be cheapish other wise I may as well buy a new pump.
Thanks everyone
dan
Mains cable wired to a plug to 240v socket at the moment. (No transformer) Surely I can slow it down electrically some how or surpress the ingoing power ?
Depending on the pump design you may find attempting to run it slower will make it much less efficient as a pump. Running it from a dimmer if it works will just covert the unused power into heat, and I don’t know of any IP rated dimmers.
If I was you, unless the pump is above 600W would bleed some of the output (water) back into the input side of the pump, this will reduce the pressure and
volume of the output and leave the pump running as it was designed to do.
Simple get a tap for the outlet you can get them from all good pet shops .... think i sounded like an ad then :D all you do is the adjust the tape for the flow you require just like the tap in your house as for the electrical consumption they are about 35 watts so consumption will be fairly low
Well it has 2 outlets. One on top for a fountain which I have closed as I dont want it and the outlet for the filter. They are both adjustable and closable. Its just too powerful so I have to have the filter outlet closed right down to slow the flow up. I just thought its a waste of electric now. Its says its 70watts.
Maybe ill sell it.
Does that cost a lot to run per day? Guess I could turn it off over night ,
Restricting the output flow will reduce the loading on the motor. This method is use for most large industrial pumps. Most of them you'd never get started otherwise.
So if I close the manual valve further so it pushes out less water, the pump will cost less to run?
Is it not the case that closing the valve would made the motor work harder because its trying to push the same water through a smaller hole but cant do it?
Or have I missed the point.
You are correct in the end the pump will burn out
All depends on the pump type. Most of these should be of the centrifugal vane type rather than a fixed stroke and will run OK with the output restricted. DO NOT try restricting the inlet as it will cause the pump to cavitate and kill the pump quickly....
Large centrifugal pumps or fans used in industry have valves or dampers to control flow. If you close the valve the loading on the motor goes down. As Graeme Harrold said don’t restrict the inlet for a pump, as the pump will cavitate causing high vibration. Most drives would not start without some restriction on the flow.
Large or small the effect is the same, lowering the flow lowers the loading :)
A lot of pond pumps these days work on magnetic induction (I think that's the term. A the pump windings are producing a magnetic current in these cases, and the impeller is fixed to a freewheeling impeller I can't imagine these type burning out. Mind I no very little about electrics.
Reply to How to slow down fish pond pump in the Australia area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
