E
easysushi
How do you guys test you meters for accuracy and keep detailed logs
Cheers
ty
Cheers
ty
Discuss How to test you meter for accuracy in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
made my own resistor box and use the same socket in thehouse for the loop tests and rcd tests.
record the results on an excel sheet similar to the sample on the NICEIC website.
I should also send it in for a formal calibration again but not had the time. Waiting for a calibration day at a wholesaler near me.
If you are with the NICEIC and use a checkbox regularly you only need formal calibration every three years
Chris
Chris
is that nic only or does it apply to all scheme providers?
Reply to How to test you meter for accuracy in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
