How to tighten a 50mm SWA gland with no access to locknut | Page 3 | on ElectriciansForums
Discuss How to tighten a 50mm SWA gland with no access to locknut in the Talk Electrician area at ElectriciansForums.net
No slots,
I've done that myself before on a temporary job running single cables from a generator to a steel enclosure acting as a JB
I could be wrong but I have never heard of any gland which stops this being a problem
No slots,
I've done that myself before on a temporary job running single cables from a generator to a steel enclosure indoors acting as a JB just for testing a machine
It will be a problem if the panel is of magnetic material regardless of what material the bushes or glands are made of. I'm really not buying this magic gland story, if it was the engineers that came up with that pile of baloney it's either some private joke they've got going on or I think they might actually be taking the ----.
I’m not aware of any magic glands that will stop eddy currents in magnetic material.
Whenever I’ve installed cables in transformers, the gland plate has always been non-magnetic.
Sometimes a right pain to drill.
I had a similar problem once. Solution was to MIG-weld pairs of nuts either side of a spacer so that each stopped the other from turning. Sprayed over the weld with cold galv afterwards. You could weld or braze them all to a spine if you could get it in as a single piece. More risk of them not lining up with the holes in the DB though.
Hmm, perhaps a solution would be before installation, to weld a short bar of steel between the lock nut and the 6mm Banjo bolt nut?
Another option would be to cut out and thread a small rectangle of plate steel so that both the Banjo bolt and the gland can be screwed through holes in the panel into the steel plate?
Yes they're just bog standard metallic stuffing glands
Basicly the guy doesn't want to redo the job, I made sure the French customers electrical Engineer knew I thought it was a load of rubbish and advised him to ask for proof of this , I thought he would press this but he's been away now on holiday for 4 weeks
Some good ideas for the gland problem very much appreciated definitely gives me other options to try so thanks to all who have contributed!
Do you mean can only tighten from bottom. If so get a steel lock nut, weld a long side piece of steel to it. So when spins locks against casing. Job done. Used to weld lock Nuts to gland plates to make tightening easier. Then obliviousy paint welds.
Ok delayed update here
Managed to get the job all done , very hard going though hence the delay of responding , actually made me quite ill thru heat exhaustion and constantly straining in tight spaces trying to get it done!
I glanded as normal with locknuts with the homemade serrations
And used a combination of 3 ft bar and hammer from outside the panel and a 4 inch bar tapped on the inside above the Isolator to tighten,
which did take a long time as constantly tapping then changing around to get the corner over just enough to use the big bar again
One of the French guys said I was
"faire l'amour" with the panel now cuz of all the positions needed and how close I was to it arms streched inside
Wouldn't say I was in love but definitely felt like I'd been @#$%&€ at the end!
Many thanks to everyone who contributed ideas!
It's such a shame you're not an apprentice - this would have been the perfect opportunity to tell you the tool you need is a 'reach around' and to head to the hardware store immediately to demand one :)
Feel free to hit that 'old' rating...
Well done though - amazing what's possible when you finally decide you've had enough and it's going to go together no matter how much of a fight it puts up!
Careful with the pxyz takes, after all, you're just a glorified plumber! :D:p:D:p
That's a terrible thing to say about a person!!
I'm a "liquid engineer". At least according to a badge I was given once. Personally I feel I was lucky to find a niche, and it all kinda worked out.
My pants remain dry. Even when I am reduced to plumbing I manage not sit in my own puddle - like an animal ;)
Reply to How to tighten a 50mm SWA gland with no access to locknut in the Talk Electrician area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
