How to wire a 240V 3-prong plug? | on ElectriciansForums
Discuss How to wire a 240V 3-prong plug? in the UK Electrical Forum area at ElectriciansForums.net
Ecuador
Hello!
For this device I have one 240V hot wire and one neutral but the socket is for a 240V 3-prong plug (two 120V-hot wires and one neutral). What can I do to install a 3-prong plug having only one hot wire?
[ElectriciansForums.net] How to wire a 240V 3-prong plug?
This is the plug
The receptacle picture shows what I think is the old NEMA 10-50 configuration for 120-0-120 service, once popular for dryers etc. This is now deprecated as it used a single prong for both neutral and earth, hence W (=white, neutral) and the PE symbol, i.e. TN-C with one grounded conductor all the way to the load.
The voltage would be correct with your hot wire connected to one hot prong and the neutral wire connected other hot prong as there is 240V between them, and the device would function, but there might be a safety issue if it does not have adequate switching / fusing for both wires to be hots.
Lucien, I really appreciate your answer.
Now it is clear how 240V circuits work. I realized I should use the third prong for the ground wire and on the other end fix it to the chasis of the device. And yes, I going to use a two-pole switch to make this device safe.
Reply to How to wire a 240V 3-prong plug? in the UK Electrical Forum area at ElectriciansForums.net
I'm now in West Virginia but my wife and I also own a home in the Philippines. The current in our province is 240v, but single pole. I have...
It would certainly heat up faster at 240V! I have a large 240-120V transformer to power my American kitchen appliances here.
