How to wire a double switch | Page 2 | on ElectriciansForums
Discuss How to wire a double switch in the UK Electrical Forum area at ElectriciansForums.net
Chippenham
Hi, I’m trying to wire a two way two switch into my lounge, i have a live feed coming from the consumer unit to the switch. I have a feed going to an external security light and also a external junction box for future garden lighting. I have wired the switch how I think it should be and it does work until I turn on the switch and then it trips, please advise on how to wire the double switch
The general consensus is, yes... you don’t connect a neutral to any part of the switch.... except one brand of switch that have now included a spare terminal marked loop, which is where the neutral goes.
just adds to any confusion.
Reply to How to wire a double switch in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
