How to wire IKEA light pendant | on ElectriciansForums
Discuss How to wire IKEA light pendant in the UK Electrical Forum area at ElectriciansForums.net
Jen Jackson
Bristol
I bought an IKEA light pendant and confused about how to wire it. The light is controlled by 2 switches and I have old colour wiring. From the ceiling I have 3 cables coming out. One is a single red cable, the other 2 contain black, red and earth.
The switch I have to put these wires into only has a neutral and a live hole.
Should I group the neutral and live cables together?
Many thanks in advance!
[ElectriciansForums.net] How to wire IKEA light pendant
Hi Jen,
The first few replies will tell you (politely I hope) to get an electrician to do it, as that is the correct advice as there's a bit more too it than just 'grouping cables together'. Then however, someone who is too eager and maybe bored will explain how to do it without going into enough detail (as there is so much more to it than joining the correct wires together) and your light will work albeit in perhaps a dangerous fashion.
Good luck :)
Jen, I would suggest that you call a local electrician tomorrow and get them to do it. Obviously check their cost beforehand, but for this type of job I charge my basic callout charge which covers the first hour. I would guess it will cost around £50 to get an electrician out, but at least it will be done properly and safely.
Jen, also be VERY careful what you touch, as I assume you have no test equipment to prove dead. There is a situation commonly referred to as a "borrowed neutral" which in simplest terms means the wires you think are dead because you've switched the breaker off for say "upstairs lights" aren't all dead as a neutral is energised from another circuit. Call a sparks and be safe!
I didn’t see any red bit come off. I think I’m just going to have suck up paying for an electrician and not buy from IKEA again!
I will admit that I'm not impressed with the quality of ikea light fittings, but regardless of the make of light fitting you would still be in the same position.
Good luck getting it sorted.
Reply to How to wire IKEA light pendant in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
I did consider this but ended up going with this one. I wired it inline with the lives and works great.
Recommended Sponsor News
Hi everyone,
