how to wire up 120 coil to replace a hoist toggle switch | on ElectriciansForums
Discuss how to wire up 120 coil to replace a hoist toggle switch in the UK Electrical Forum area at ElectriciansForums.net
M2b3c3
Hi guys,
I have a hoist that operates with a wired remote toggle switch; please see attached the hoist wired remote schematic.
I would like to build a control panel to replace the wired remote using two coil contactors. I am planning to use two Siemens contactor switches (3RT2026-1AK60 3-Pole 25A Contactor 120VAC Coil) for this purpose.
I need to know how I should be wiring these contactors to allow me to operate the Up and Down function of the motor, while not allowing engage both functions at the same time. I like to add the following features to the new control panel as well:
  • An emergency stop switch
  • An upper limit switch
  • A lower limit lower
I am familiar with electrical safety... your guidance on how to wire up the new circuit would greatly be appreciated!
  • Hoist Remote Schematic.docx
I got my degree in the early '90s, however, never practiced in my discipline...hence I am very rusty. When I said I am familiar with electrical safety, I meant I could read schematics... but likely it would take me quite a while to do a new design... I am not dumb to do anything risky so thought I could get some support from you guys who are experts...
Reply to how to wire up 120 coil to replace a hoist toggle switch in the UK Electrical Forum area at ElectriciansForums.net
That is a big assumption (like a garage saying briefly as you pay the bill, other than the brakes not working, it’s good to go) generaly speaking...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
Thought this was sounding a bit familiar. A thread on the same subject from 2021,, There's a link to the manual, but no diagrams, in my post #2...
6K
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Interesting post, thanks. I have done some fairly simple electrics in Spain, but they do have some unusual rules...and some very unsual practices...
