How would you do it?? Two way on 12 lights, some dimmed, some not | Page 2 | on ElectriciansForums
Discuss How would you do it?? Two way on 12 lights, some dimmed, some not in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi
I have a job with a customer who wants his new kitchen which has been designed to have two way switching ofn12 sets of lights, some off them dimmed and some just switched.
My question is how would you do this? Client wants one bank of switches so grid set up best, a lot of cables to each switch bank, I have wired everything back to one point so I can put in a big adaptable box with din rail mounted connections.
Any thoughts on how you would attack this, I have 18 cables at one switch bank!!
If that number of switches is really necessary I'd probably be running a multicore cable from each switch to the JB.
But then I do have a lot of 19core sitting in the warehouse due to a slight over-ordering incident.
With 18 cables are you running 12 x 3core then 6 x switch wires to each switch bank? There are plenty of ways to cut back on cables at the switches but I think you will end up creating more work and taking longer.
If you're restricted with space I would say conduit and singles with a feed at one switch and then just run twins with switch wires at other switch.
I have got as follows 15 cables not 18 as I first said,
I have a mixture of some 2way, 3way and 4 way switching.
All wired in 3 core into deep back box ready for a grid setup.
My first post wasn't as clear in regards the switching which helps explain the amount of cables,it's all wired back to a box which will be next to the db, splitting it into 3 circuits on seperate RCBO's
Reply to How would you do it?? Two way on 12 lights, some dimmed, some not in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ha.had a whole school corridor like that when I was an apprentice ,was only changing type of fitting .nightmare .couldn't work out why there was...
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
