HSS Drills any one know good quality make | Page 2 | on ElectriciansForums
Discuss HSS Drills any one know good quality make in the Electrical Tools and Products area at ElectriciansForums.net
We use tungsten carbide drill bits at work for drilling out stainless steel and titanium fasteners, only problem they cost a lot.
I am about 3/4 the way through a trailer build all stick welded, and now I am attaching lash points etc I bought a well known diy brand but got 2 x 8mm holes and its knackered I know I can be a bit heavy handed at times but come on 2 holes, so I am looking for what my Granddad used to call blacksmith standard they were bloody dear back in the day so heaven knows what they will be now but advice is welcome
Pict
I would suggest that you consider investing in a 13-piece DeWalt DT7920B Extreme Drill Bit Set. I bought a set 18 months ago and have been well-pleased with their performance.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
We get Somta drill bits locally, also FEW (French Engineering Works), they're not the cheapest but they're both very good but I'm not sure if either brand are available in the UK.
Don’t buy from UK Drills, they are terrible.
I used to own a machine shop, 8% cobalt are good, if you are only drilling shallow holes then use stubs drills.
I used to buy from ‘CNCPOORBOY’ on eBay, I’ve bought an M5 spiral point tap just a hour ago. Look for cobalt stub drills.
And use a good tapping/cutting compound to extend the life of the drill bit.
Carbide is too brittle for a hand drill, it won’t last and side movement. Even dropping them will shatter them!
I can also recommend these. Last ages.
However, if you're drilling a hole through anything less than 1.5mm steel with anything larger than 6mm in the set. They bite that hard going through that it'll deform the metal and try to take your wrist with it.
They don’t have the standard angled tip, probably easiest with a picture:
[ElectriciansForums.net] HSS Drills any one know good quality make
Reply to HSS Drills any one know good quality make in the Electrical Tools and Products area at ElectriciansForums.net
