Hydroboil trips mcb ??????????????????????????? | on ElectriciansForums
Discuss Hydroboil trips mcb ??????????????????????????? in the Electrical Appliances Forum area at ElectriciansForums.net
SCOTLAND
hyrdoboil trips mcb? Element is 2.4kw ohms test was 23 Ohms and IR was 300 odd. Had disconnected element from thermostat and power did not trip but element seemed perfect
Hi,what else is on the same circuit,and 300 odd what?
Sometimes,it takes a few cycles or change of duration,to tempt a faulty element.
Have you seen it trip? If it's repeatable try a toaster in that outlet and see what happens. If it trips too then perhaps N-E cable fault somewhere.
Reply to Hydroboil trips mcb ??????????????????????????? in the Electrical Appliances Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
