J
juniperz
Well the installation was completed yesterday.
I have the Power One PVI 3.6-OUTD-16A mounted on fire retardant board, with isolators labelled properly, and the 16x Suntech STP 245S 20Wd wired as 6+10. There is a wiring schematic (showing 6+10) in the cupboard next to the generation meter in the utility room, and a Wattson Solar meter (provided) quietly glowing. When I was home yesterday (wet and miserable), I didn't see it go above 600W, but my wife allegedly saw over 3000W today.
I guess I should be happy, but there is a bit of a sour taste because it took such a lot of effort...
Thank you all for your help - I don't know quite how I would have got to this conclusion without you. What did we do before t'Internet?
I took a few pictures yesterday, while the scaffolding was still up.Comments welcome...
When I am home again on Thursday, I will take some internal shots too.
I will also see what the peak output has been from the inverter display, and what the startup voltage for the string of 6 has been set to. Power-One String Tool says it should be 185V, if I have interpreted that correctly.
Following recommendations here, we are going to go with Good Energy as the FIT provider.
